Would pretty much agree with Jerry (Hotrod Lincoln) except would start with 1 turn instead of 1 1/2 on pre-smog (1968) carburetors.
And 310kms per 60 liters is about 14 1/2 miles per gallon - not too bad.
Check your tires for proper inflation, and also check to make sure you do not have a brake that is dragging.
Jon.
The Carburetor Shop
