| | | Forums66 Topics128,167 Posts1,057,022 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63935 08/06/2006 4:27 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | leon2982,
Your problem sounds like classic clutch chatter to me. The bum center bearing support might have added to it...a little, but a new clutch, pressure plate and flywheel surface will probably fix the problem nicely.
Reverse would tend to exacerbate the chatter because it is geared so low. If you have oil getting into the clutch area, that might complicate matters.
Stuart | | |
