I like the 3/4 ton because it is not the same as all the others out there. The ones guys do buy usually get shortened, a new set of springs and an axle swap. I just got a set of origional 8 lug wheels and plan on keeping mine stock-ish. You can also get a nice truck for a better deal because it is "less desirable".
Mike
