Don't overlook the ground side of your circuit. Many times this is not considered but if the ground side connections are corroded it will increase the resistance causing a voltage drop.
Every connection is a possible slight loss of voltage and while just one is no big thing add them all together and the situation becomes greater.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
