8 members (Gdads51, Steelonsteel, TUTS 59, Mike Burns, Mike'sPlace, Wickedbass, moparguy, 1 invisible),
98
3
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63730 08/07/2006 11:10 PM | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | I have used ATF to free motors. Pour the ATF in the cylinders through the spark plugs and reinstall the plugs. Let it set for a day or two and then try and turn over. The ATF will loosen the rust and if starts it will smoke like crazy. If your rings and cylinder walls are rusted as well as any other parts that move in tight quarters, scarring is most likely going to happen. Have a good time with the hone after you get it to turn freely. | | |
