Ditch the 8 volt and put the correct battery back in it. If you MUST use the 8V for some reason, have the voltage regulator adjusted to make the generator produce 9 volts. Then go out and buy a BUNCH of 6 volt light bulbs, headlights, etc. You'll be needing them.
