10 members (Gdads51, JW51, Lightholder's Dad, Otto Skorzeny, MickeyP, FAST55, dt235sd, Pre '68 Dave, Peggy M, 1 invisible),
100
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | As long as you have the axle in plane with the transmission, don't worry about the horizontal degree. Next time you are at a big truck dealership, look at the angle of the inter axle drive shaft. I'm not sure what you are reading, but it may be the minimum offset. U-joints have to have an offset. If not, the needles will stay in the same place and wear into the cross in no time. | | |
