| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | The one ton consisted of a 2 piece drive shaft. Now I have simplified it by making it a 1 piece and the angles of the original were slightly off center to begin with and the 2 piece was extremely angled if anything. If I understand the comments above correctly as long as the 2 pinions are on parallel planes from a horizontal perspective and a height perspective that the corresponding angles are within 1 degree of each other that they should in fact work without an issue. Now based on the fact that I am within 3/4" - 1" over a +50" distance I would assume the angle that I am questioning should be within the limits of the joint. As with the overall height difference between the Transmission and the Axle, the second half of the 2 piece worked at less of the distance that I am going to be making the one piece which created an extremely large angle.
