All three speeds will have 1:1 ratios in high gear, so putting a different three speed or even four speed in won't change the engine revs per speed. An overdrive or a five speed with overdrive fifth gear would be options.
You may be going about 20% faster than indicated if you didn't change the speedometer gears in your transmission.
