9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wiltrek, the directional control valve is rebuildable, but parts availability may be another story. This valve uses very tight clearances, and small movements to direct fluid flow from one side of the ram to the other, and if there are any voids in the fluid the motion will not be constant, hope that helps. | | |
