3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | What I have found in the few that I have dissassembled (both cars and trucks) is that the bearing surface on the worm shaft is damaged. Generally the upper bearing runs out of grease and wipes out the bearing and the shaft becomes badly pitted. This surface is hard chrome and could be redone or the shaft replaced. There are kits available with bearings and small parts and the book gives a good rebuild procedure. There are a couple of sources in my area that do a good job rebuilding steering boxes and are reasonable. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
