| | | Forums66 Topics128,260 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63136 07/20/2006 10:54 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Wrenchbender is right, a little rust doesn't hurt the ring and pinion gears. You'd want to clean it off with a rotary brass wire brush before reassembling so you can get your backlash adjusted right, though.
Patrick's one piece bronze bushing has the oil seal pressed into one end and is turned to the correct diameters on both ends to replace the original two bearings. It is a good setup and easy to install. | | |
