8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is normal for the ammeter to go to the 0 charge when the battery is good & fully charged. If the volt meter stays at the normal charging rate when you rev it up, 7-7.5 volts you are good to go. Turn on the lights & heater. The amp gauge will go to discharge. Rev the engine & it should go to a charge & settle back to even. When the bat. is fully charged it has the same voltage as the charging system. There is no flow of amps back to the bat. It's like you have a tank with 50 lbs of air pressure. You put it to a tire & when the tire gets 50 lbs of air pressure there is no more flow. If the charging is falling off at high RPM's the belt may be loose.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
