9 members (Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, homer52, 2 invisible),
95
3
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | If your hi-beam were bright you probally don't have a ground problem, just a adjustment problem, pull up to a garage door turn the lights on and see where they point. Check your Chilton manuel and see the proper way to adjust them. Granted the new lights are far superior to the old but if they are not adjusted properly they are not much good either. The Cool Blue's are great behind the steering wheel but coming at you they arent cool at all if not adjusted properly.
You Learn more Listening than Talking
