9 members (48ed56pam, Gabes-trucks, keith, 52Carl, Gdads51, Steelonsteel, dt235sd, J Lucas, 1 invisible),
250
0
Mod | | | Forums66 Topics128,081 Posts1,056,075 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62844 07/10/2006 3:41 AM | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | I'm looking to swap the 3-speed tranmission in my '48 1/2 ton for a 4-speed with granny gear. I'm thinking sometimes I might like the granny gear to get my boat up the ramp at low tide. I can get a 4-speed with either yoke. Is there any reason why I should switch from the original closed driveline when making the swap? I figure if I'm in there swapping transmissions then I might want to do some other work that makes sense at that time. Basically I have no clue. | | |
