| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Don't know if it works or not, but investigate a 48-53 1/2 ton axle with disc brake conversion. But you'd loose the 1.5 ton truck capacity and the dual type wheels up front. For a more substantial axle swap read through this Tech Tip and check out the axle pictures http://www.stovebolt.com/techtips/bigbolts/p30swap/Grigg | | |
