Try this, It only costs a filter. Remove the oil filter, fill the new one with oil before installing, it. Your filter has probably drained dry and caused the pump to fill with air also. The filter full of oil may be enough to get it pumping again. But, you have to be quick to get the filter on before all the oil runs out!.
