9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That number is the Serial number, not the casting number. The casting number will be found towards the front of the engine on the RH side near the bottom of the block. Unfortunatly, the codes I have only cover up to 1 ton, so I can't really decode it too far for you. I can tell you that the L in the code does equate to 1953. I do know there is a site with the codes, but I do not know the site name.
Bill Burmeister | | |
