| | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62280 06/27/2006 5:36 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There should be a zerk fitting in the cross of the joint, unless someone has changed it to a sealed unit. The fitting will be located between the ears of the yokes at an angle, usually toward the center of the driveshaft.
Bill Burmeister | | |
