Thanks 3B, that has been the case before, but this time it happend with full oil (overfill actually). The problem started after an oil change, when appearently I didnt get the gasket around the canister oil filter on right (duh) and it shot oil out at pressure while I was test driving it. So I stopped fixed the gasket and added the 3 quarts it needed at this point and continued to drive on. About 20-25 miles later im having this on and off again oil pressure problem.
