7 members (cmayna, 55shaker, Gray_Ghost, Otto Skorzeny, Hotrod Lincoln, MikeE, 1 invisible),
131
3
Mod | | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if the truck is new to you the best thing to do is drain and refill it - if the oil you drain looks terrible [watch for sludge and evidence of water] you might flush it with some kerosine then refill, good to do with the rear too
the plug on the side is the fill the level, if you just want to check level stick your baby finger in there and see that it's up close to that level
Bill | | |
