| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't have a 40 model but on my 51, there is a spacer that sits on top of the spring. It is shaped to hold the U bolts in position. My shock plate is mounted on the bottom of the spring and the U bolt nuts tighten against it. In addition there is a caster wedge between the spring and the axle on each side. | | |
