| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Looks like this one doesn't oil from the engine like the newer ones do and it appears to be air cooled instead of water cooled. The governor which is the thing on the side of the compressor toward the firewall looks like current production ones. If it ever quits pumping, that will probably be the cause and they can be bought at any heavy truck dealership for about $12. Other than that, check the oil regularly like you would a shop compressor and you will probably never have trouble with it. Sounds like you made a heck of a buy. | | |
