| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | About the only thing you can take apart from it is take out the lock cylinder. That is done by using a paperclip to depress the little button in the hole. The hole is on the face of the lock cylinder where the key goes. It may be dirty or have crud in there so you can clean it out. If you have a shop manuel it details how to take it apart. Or a search on google would bring it up. If you have a voltmeter that can test for continuity then you can hook up the leads to the power and other terminals on the back and see if you have continuity in all positions. If you don't you may just have a bad ignition switch. Good luck! And hope I didn't confuse things for ya!
58' 3200 235 3-speed/OD
