When the vaccum motor hits the spot where it stops can you hear a leak? How do you get the wiper arm to return from the position it stops? Can you move the wipers all the way thru the path by hand? I'm thinking if the arms are free and the vaccum lines are good, your motor may require a rebuild or at least a good cleaning. Check all the hoses looking for cracks, obstructions and so forth.
