9 members (3B, Bill Hanlon, JW51, 57 Drifter, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
64
3
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61859 06/17/2006 8:47 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Like Baldy said what is "nothing"? It takes spark, fuel & air. I would first pull the fuel line from the carb & crank it. If there is no fuel it could be a plugged fuel line, bad pump or no gas in the tank. If there is fuel to the carb pull a plug wire & crank it with the ignition on, holding the end of the wire against a ground. No spark check the ignition components. If you get a spark it could be a plugged air filter but that's unlikely. I would then go back to the fuel system, pull the top off of the carb & make sure the gas you're getting to the carb is going through the carb. If it's been sitting that long there's a good chance you have a varnished carb & need a kit.
