9 members (JW51, Wickedbass, 50Chevy3100, 59 fleet, msmall, 68ironhead, Shardean, DannyW, Eisenholtz),
46
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The drive may be slipping. Many times they sound like they are grinding against the flywheel teeth when they are slipping inside themselves. Either way, check the drive carefully, and check the teeth on the fly wheel while the starter is off to make sure it isn't messing up the teeth. | | |
