i am putting a 350 in a 1/2 ton with a 96 s-10 frame make sure u get the motor level and yes u will have to make most of the mounts your self lockor makes a great shifter trans mounted with and e brake cable mounted to the same bracket will send u some picks of that set up tonight when i get home i love it and u will have to change radiator or add a trans cooler it is a tight fit and yes u might want to run an eletric fan and water pump
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
