1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Why a toggle switch? Most regular ignition switches will carry the current for a HEI without a problem, or if you're concerned about overloading the switch, you could use it to turn on a continuous-duty relay triggered from the "run" position of the switch.
If you choose to use a toggle, a 20 amp should be plenty of capacity. Jerry
