| | | Forums66 Topics128,087 Posts1,056,372 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61471 06/10/2006 11:48 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't forget to add a 2nd drain plug ahead of the notch so you can drain the oil from it. Ferd had to do that on the 302/351 in the fox body and ltd to clear the front crossmember. Lots of guys miss that plug when they change the oil.
Bill Burmeister | | |
