1 members (Hotrod Lincoln),
57
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61437 06/07/2006 3:14 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The center clamp bolts torque to 15-20 ft lbs. and the outers are 25-30 ft lbs. I couldn't find a spec for the bolts that connect the 2 manifolds together at the heat riser. I suggest replacing the 2 dowells at the outside ends of the exhaust manifold with bolts/studs. It really helps with any leaks in the manifold gasket.
Bill Burmeister | | |
