7 members (MickeyP, Rusted Nut, Steelonsteel, 5 Window 9434, Dennys28, Southerntruck, mick53),
91
3
Mod | | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61386 06/06/2006 10:13 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I just checked the vacuum on my rebuilt 261 and fiddled with the timing, and got only a mas of 15 inches. I thought it was due to the 3/4 cam or dual carbs, or leaky gaskets or bad valves.
However, after checking all that I talked to a friend and he said that engines produce less vacuum at altitude. Where I live is about 5,500 feet above sea level. My friend said its about 1 inch per 1,000 feet. He said 15 inches is good here and it would be 20-21 at sea level.
Has anyone else heard this?
'51 Chevy 1/2 ton w/'62 261, HEI, offy, fentons, dual carter/webbers, t-5 & 12 bolt posi
