| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Is it a 3 or 4 speed? If it's a 4-speed floor-shifted unit, it's probably a SM-420, the original-equipment transmission. The 3-speed column shift with the torque tube would also be original. Either one will have the same transmission bolt pattern as the later-model open driveline trans. Jerry
