| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | On my '49 1/2-ton, the center to center dimension between holes is 7-5/8". However, the holes are at right angles to each other and the rod has an angle at one end. It might be a challenge to fabricate. I don't believe the part is available from vendors. Suggest you try posting a want add in the swap meet. | | |
