| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Since I’ve got the motor and steering gear out, and the entire front clip off the old gal this winter I figured it’s time to finish up the front end work. All that’s left on the suspension/steering now is to clean up/check out the springs and replace the bushings.
Since I don’t have access to a 1/2-ton front spring to compare my 3/4-ton front spring to I’m gonna have to depend on my you, my buddies here on the bolt. I’ve been under the impression that the 3100 and 3600 springs and their mounting were the same. In fact the whole front section of the frame should be the same on both from my past research. In The Filling Station’s catalog I’m looking at the front shackle bushing info and they make no mention of the 3/4-ton in their listing; http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z56330~P6.00~~~~S2UH0FGXW024119617636b~Z5Z5Z5~Z5Z5Z50000014x (sorry bout the hyperlink, cant post a two line link I guess.) The listing for the front spring-rear eye threaded bushing seems fragmented again. It clearly says 3/4 & 1-ton but doesn’t mention the 1/2-ton, which I thought was supposed to be the same as the 3/4-ton.
I want to get the order in today so I’d appreciate hearing about your experience or any feedback you may have.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
