| | | Forums66 Topics128,041 Posts1,055,489 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61107 05/30/2006 6:54 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | OK, that was a funny "yoke".
The item which mates with a u-joint is called a yoke. The Saginaw does not have a yoke on it for a u-joint connection; it has a splined shaft shrouded by the transmission housing. Maybe more than 1 word is used to precisely define the name of the part I need with yoke being one of the words?
The part I'm talking about will fit between the long section of the driveshaft and the other end will slip over the splined shaft of the Saginaw and into the tranny housing. Having never seen underneath an automobile with a Saginaw tranny I am GUESSING that the part I need will replace the short front end of my driveshaft.
Mike Barnes 1950 GMC 1-ton pickup
