Stan ISO 46 is hydraulic oil. you would be closer to ISO 260 (SAE 50) or ISO 320 (SAE60). UTF (Universal tractor fluid) is simply mineral based hydraulic oil with viscosity modifiers and is used in everything from the transmission to the hydraulics to the axles on a transmission. It is generally a bit thick for hydraulics and a bit thin for axles and transmissions, however it is intended as a compromise so there is only 1 fluid used for service.
I'm with Crenwelge, Synthetic SAE 50 makes transmissions happy.
