| | | Forums66 Topics128,134 Posts1,056,403 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | JDF1986,
What weight oil are you using in your oil bath ar cleaner? What year is you engine?
The 216/235/261 engines' oil bath air cleaners are supposed to have 50 wt oil. Lighter oil might more easily migrate up and into the carburetor (requiring more frequent addition of oil).
The owners' manuals indicate no set time period between checking the oil bath fluid level and also do not indicate the amount that might have to be added (manuals state interval and amount "As Required""). I have never had an oil bath filter "dry out" if I check it at every oil change.
