| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | 1. Buy a tape measure
2. Crawl under the truck
3. Measure the distance from the headers to the ground.
4. The measurement is how far you can lower the truck.
5. If you want to drive it instead of just letting it sit around at car shows, it might be a good idea to leave a couple of inches of clearance so it will only drag the pipes when you hit a bump. Jerry
