1 members (delky),
65
2
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60942 05/26/2006 1:42 PM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Simple question that I can't directly find the answer to in the archives: I need to replace my rotted out old engine mounts, you can see the starter pedal jump around quite a bit when you let the clutch out.
So, can I just jack up the back of the engine carefully, unbolt the transmission mount and unbolt and remove the old bell housing mounts? Or is there more to it than that?
Thanks for any insight. | | |
