1 members (Phak1),
65
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would track down another compatible 235 manifold with a working or almost loose heat riser system. I would also have the manifolds trued up at a machine shop to any grind warpage out of the exhaust manifold. With some new gaskets, your system will be like new and do what it was intended to do without a buntch of leaks.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
