| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60906 05/25/2006 3:07 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | This is an interesting question. I gotta believe that you will find many different temperatures at various places on the block and head depending on where (how far away) the water jacket is behind the surface you are checking. My first try would be to carefully remove the radiator cap and directly measure the water / antifreeze temperature. It should really be your thermostat that sets the temperature and it is the water temperature that the gauge is measuring. | | |
