Originally posted by OldSub:
Both the Powerglide and the TH350 have direct as the final or top gear same as the stock 3-speed.
I guess that means I've got some low gears then! This 250 sounds like she's winding pretty tight when I get up over 60mph!
Did they normally put low gears in with the 250/3 speed combo, or were most of them geared low no matter what combo?
