0 members (),
129
3
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | They all have an internal passage to feed the rocker arms. Plug the hole with a pipe plug. It sounds like somebody before didn't know where to route the filter lines. The lines should run from the same passage the oil pressure line exits the block to the top side of the oil filter. And from the bottom middle of the filter to a passage near the middle bottom of the block. HTH.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
