| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60367 05/12/2006 7:12 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A headlamp relay can also be used if you can't find an original unit. I used a Standard/Bluestreak #LR-32 and it works perfectly. I also added a switch to deactivate the o/d when not in use.
Bill Burmeister | | |
