| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | One thing to look at on these valve covers, be it Offy or Waynes (I have a Waynes) is the lip where it contacts the gasket. Make sure it's flat. I had to have mine flattened to get it not to leak. Set it on a flat surface and check it with a feeler gage. If you do this first it will save you the frustration of taking it off and fixing a leaky valve cover. George | | |
