| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Hi,
I have to do a little maintenance on my brakes (bleed lines, replace the hoses, get the emergencies working) and wondering if anyone has any good tips on:
1. Getting brake fluid into the master cylinder? Is this best done by removing the floor board or is from below easy enough.
2. My emergency lines don't look too bad but are a little frozen. Are there good ways to loosen them up (WD-40) or is replacement the go to solution?
Thanks for your thoughts,
Doug | | |
