7 members (Gray_Ghost, JW51, kades51, Wally / Montana, Bill Hanlon, warlock, 1 invisible),
70
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Actually, the gaskets are supposed to stack up until there's a slight clearance between the bell and the cover. It's not uncommon to have to use more than one, kind of like setting the worm gear bearing preload on a steering gear by adding or removing a series of thin gaskets. The side clearance on Ford banjo housing rear axles are set the same way, with single gaskets of variable thickness. If you need to add more gaskets, you don't have to pull the torque tube again. Just make a diagonal cut at the top of the gasket, slip it over the bell, and dab a bit of #2 Permatex at the cut site for sealing. Jerry
