truck looks good...my understanding is that within 72 hours, the epoxy primer is still soft enough to bond with the 2k primer's reducers - thus negating the need to sand. Also, if your shop temperatures are lower than 70 degrees, you probably have more than a 72 hour window. I would try to recoat within that recoat window, becuase alot of epoxy primers sand like garbage.
