| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59765 04/27/2006 6:53 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can get a lot more mileage out of your engine if you use aluminum pistons when you rebuild your engine. The main reason the babbit goes bad is the inertial forces caused by the heavy pistons. I talked with a 39 owner who uses babbeted rods and drives 70 mph regularly with no damage because he put in aluminum pistons. I bought a set of .030 over aluminum pistons that I'm going to use when it's time to rebuild my 38.
